How would you actually prompt an AI to design your next build?
Realmdyz
Lately, a particular topic has really been on my mind!
As you know, knowing how to interact with AI is crucial these days (at least, that’s my take!). That’s why I want to bring this up: imagine you have an AI at your disposal that can design and even manufacture RC models for you, whether it’s an airplane, a car, or anything else. The question is:
How would you craft your request or "prompt" for this AI?
This is a really important part, at least I think so!
Would you use just a single prompt? (I’d appreciate it if you could share the details and write out the exact text of that prompt.)
Or would you use multiple, different prompts? (Again, please explain how you would structure them.)
For instance, suppose you were limited to providing just one prompt to the AI.
Personally, I’d probably provide precise details about the RC model I had in mind, yet leave certain aspects open and undefined so the AI could make those decisions!
What kind of prompt would you use?
CRASH 22
I used ChatGBT to help design my twin V 1200
I was going to cut the wing where the props would be close together and eliminate the two wheels in the middle
It recommended to move them further apart and keep the two middle landing gear ( all four ) because of weight
( the single V 1200 is a really heavy to start with, esp with a 6s 5000 battery )
it also recommended counter rotating props. I didn't use them on the first first flight.
( had to order them ) and the plane showed that I needed them
( any more power than half throttle, it would pull hard right )
the second flight with counter rotating props crashed on takeoff because of pilot error.
the plane veered right on take off and almost hit another pilot, we over corrected and the plane went in
it is repaired now. I hope to fly it again next weekend. ( we have a Hurricane this weekend, Oh Joy.... )
This got me thinking, what if there's a challenge to fly some of the wackier early AI aircraft? Back a couple years ago the image generators made some pretty unique designs which remind me a bit of the 2018-era Flite Test "will it fly?" videos. Seems like the sort of thing @FoamyDM would try out.
As for a good prompt, maybe try something like "Design a model plane out of 3/16" Adams Readi-board in the style of Flite Test, for XYZ motor and battery specs, with the center of gravity at 1/4 the chord of the wing". I wonder if the AI could make accurate plans for foam board?
I usually only use it for estimating needed thrust, best airfoil types ect, then model it off my general knowledge using the tips it gives me👍 (I tell it what I want to accomplish with the plane: cruise speed, stall speed, weight, my motor, esc battery ect and usually it will help a good amount)
I have tried and NO it definitely cannot design plans for even very simple planes like FT's EZ planes...While it might get the shapes pretty close, the scaling ect. is terrible, and as it will admit to you if you ask it, AI generation does a very poor job of getting things dimensionally correct.
telnar1236
You might also need to check thrust line. The V1200 likely has built in right thrust to counter p factor and torque, but with counterrotating props this is unnecessary and will cause the plane to yaw/roll right. The down thrust is still helpful though
telnar1236
I think an important part of designing an AI would be it being able to accept any reasonable prompt from "design me an rc plane" to "design me an rc plane with these electronics" to something very detailed. If you have to spend an hour engineering your prompt, you might as well spend an hour engineering your plane instead. Another important thing would be it being able to modify something that is actually the same design across multiple prompts instead of generating something new each time.
Timmy
you should ask AI to make a prompt for you
31SamCoMi
I have been building a 27in Nutball and I have been using it to figure out target weight and things like where I want the spar. However, nothing beats human input where experience actually happens.
