FlamingRCAirplanes
Bro
As promised in the video, I have started work on the quad-rotor cyclocopter. I have realistic hopes to have it built by the middle of the week and have flight near the end.
but I already have the CC3d flight controller
It kinda seems like you're affecting a child/student attitude towards engineering.
The way a corporation looks at this situation, they just paid $$$$ to get that prototype built. Buying a brand new F405 is really cheap compared to totally rebuilding the prototype after RUD induced by a ten year old F103 running the wrong code.
That's looking pretty awesome.
One thing that kinda jumps out is that with no fuselage and just those two tubes, I don't think you have any torsional strength between the front and back. I'm not sure if that might cause flight dynamics problems.
They're M2x8 screws; each weighs around 0.2g. That adds up to 2.4g per rotor, which I'd say is pretty insignificant. I'm not sure how strong nylon screws are, but each blade is pulling around 270G of centripetal acceleration; with the blades weighing ~4g each, that's around 500g of shear stress per screw.What is the total weight of all those metal screws holding the rotor blades? Would nylon be strong enough?
I really like this thread. Just love readin about all this cool stuff. Great job man! Keep it up!Exciting news: I broke a 4:1 thrust/weight ratio today.
Given Nick's success with fairly high thrust levels using the 2204 motor, I thought that I'd try it just to see what the thrust would be like. The thought is that it would have more torque than the 1808 motor that I'm currently using, but honestly I'm not sure how they would compare. I also chose a Goolsky 2204 1400kv motor (in comparison to the 1250kv I'm currently using) with the thought that it would also have slightly higher rpm and therefore thrust. To be honest, I'm not sure how a 2204 1400kv compares to a 1808 1250kv, so I just thought that it would be worth a try to see how well it would work.
I reached a max of 408g thrust, with the rotor weighing in at just at 100g. I need to do some soldering before I can test for the efficiency, but based on warmth of motor it seems pretty comparable.
EDIT: Just realized that this thrust measurement is based off of the thrust stand. As mentioned in the previous post, it is somewhat unreliable. The intrinsic value should be around 340g. However, that's still significantly higher than the previous intrinsic value of 280g thrust.
EDIT 2: Just tested efficiency and recorded values. The values are pretty much exactly the same as running it with the old motor. (+/- 3%) Yet as stated earlier, the max thrust peaks out 20% higher than the previous max thrust (330g vs 400g). I think I'm going to stick with this motor.![]()
I'm estimating they are rotating at about 3000 rpm with the 1900kv motor and 3:1 gear reduction:
(1900kv * 12v) / 3 = 7600 rpm, *guessing* closer to 3000rpm under load = 314 rad/s
Awesome, looks great!I'm curious about (1) aspect ratio (2) number of blades (3) whether to put the control rod forward or aft of the blade pivot.
(3) Not completely sure about this and I'm currently trying to write a paper about it, but I think forward. If it's backward it makes the blade pitch more on the top than the bottom, and if it's forward then it makes the blade pitch more on the bottom. Due to virtual camber on the bottom, it should be more effective to have a higher pitch there. This is not completely understood, and it might make sense to make one rotor then test both configurations. <= Actually this might be good to do before you build all four rotors. Lol it took me a year to get it to have a T/W ratio where it can lift a cyclocopter off, so you probably should iron out all the bugs before building all of them.
If your motor is getting even remotely hot, you're on the right hand side which is the no-go zone for efficiency.
