I had no idea that this thing would have the turning radius of a Greyhound bus.... The wind finally settled down to just a gentle breeze and I went and flew it again after tweaking the CG. The second flight was much better and not particularly stressful. I was able to mess around with the flaps a bit. There was just enough breeze, that with the flaps down, I could almost get it to stop in the air. I was surprised that I didn't have more rudder authority. I had the rate set to 80% and the expo at 30% and it seemed to be a bit sluggish. I pumped up the rate and turned down the expo, it seems to be a little better behaved and did turn a little sharper on the ground. Unfortunately, by the end of the flight, and after the adjustment, I was out of daylight, so we wrapped it up. We'll see how the new settings do next time I fly. I also added some elevator mix with the flaps, I had to hold quite a bit of down elevator with the flaps deployed.
Here's a crazy take off where I almost hit my camera woman (wife). I am much better on the ground with my T-28, tail draggers are still a bit of a challenge for me.
Here's the landing from that flight. I definitely need to learn to slip a little better, I still really struggle with a cross wind, thus the final landing position of the plane:black_eyed:
I was able to compensate for the washout with a mechanical adjustment of the aileron on that side. I am still fixing it, as a matter of fact, the epoxy is drying right now. I think my aileron tweak is actually inducing a bit of yaw.
I need to get an RC plane aerodynamics book. Being a nerdy engineer I like to study things in books and then apply it physically. I need to do more builds like this, it is also a great way to learn about aerodynamics and how planes work.
