You will need the lead for the DXE that connects to the phone app so you can sort that out.
I suspect your trouble is that you have not got enough channels on a 6 channel DXe to operate both the SAFE modes, panic switch and flaps. You should read the manual, it shows you which channels to set up.
1-4 are the usual controls, 5 (gear) is set to SAFE on/off and 6 is flaps.
Also posting the same question in multiple forums is not good, it annoys people who might be able to help you.
