I have twins.... :)
CarolineTyler
I couldn't resist, made some changes to add a rudder on it and upgrade to 40A ESC
Twins - like the film ;)
Something looked off from the start. Definitely got worse power off. What did the post crash reveal?
CarolineTyler
It flew great until the shutdown of the EDF. I decidied it was either the ESC doing a thermal cut-out or losing the signal from the receiver. I have a couple of failure to arms afterwards which makes me think it was more likely a signal issue. To play it safe I've added a heatsink to the ESC, carved out some internal foam to provide more airflow and swapped out the receiver for a different one - Lemon DSMX to Jumper T16 (FRSky protocol).
I did give it a couple of flights this morning (1 on 3S and 1 on 4S) but the weather was horrible - 18+mph winds, cold and full of turblance so I was concentrating on not crashing than making a video. My eyes were all tearing up from the wind :(
CarolineTyler
Well: do a video so I can say, Wish I could do that.
What happened to the mandatory strobes?
Glued together with E6000 which is the very best foam glue in my view. It has just the right flexibility. A long snap-off blade to increase airflow, a heated up screwdriver to smooth off the cut areas. The heatsink is one of those I.C. heatsinks, it was a bit tall so used a dremmel cutting fick to shorten it a little.
No strobes, this plane will not be flown very far away.
Insanely Addicted Techno Geek
Another thumbs up for E6000! I've used it a a few foam builds now. Thinking about trying it instead of hot glue on a FT foamboard kit for fun....
