I just got a 64mm edf, What should I do with it?
TreadHead98
As the title implies, I got one of these 64mm EDF units from a friend, and now I need to figure out what to do with it. Any ideas for something interesting to build around it? Looks are a pretty high priority, so I’d like something that actually makes a good-looking airplane, not just something to stick an EDF in. And before anyone says it: no FT Viggen/x-29. :)
Thoughts?
L Edge
If you noticed, not too many planes out there with EDF's. Biggest problem is the weight. With a 64 EDF, the usual weight for flying is usually between 1.2 to 1.5 lbs. If you add up EDF, ESC, battery, it doesn't leave much weight to build the structure. Hence, your "good looking airplane is limited.
One way, is 3D printing like @telnar1236 or see what you can find in plans on the internet. Suggest you also check out a flying video of that model to insure it flys. If you don't build light, it won't fly right.
telnar1236
Looks like a reasonably powerful unit so you should be ok to do something a bit more aesthetic with a bit less worry about weight. My personal philosophy is that aerodynamics and good ducting matter a lot more than pure thrust to weight ratio, but that isn't necessarily the general consensus, especially for foam board designs.
The F-117 has always struck me as being well suited to foam board with its faceted shape.
If you're interested in 3D printing, 64mm is a bit of a bad size for it. Looks like there are some designs on Owlplane and some others scattered around from individual designers, but I can't really vouch for how well they fly. Most websites jump from 50mm straight to 70mm or 90mm if they have larger EDFs at all.
If you're interested in either of my 64mm designs, I have the Falcata and the Rapier - both fly great but remain slightly WIP - so I can throw together the STLs pretty quickly.
telnar1236
Here's the thread I started on it - reminds me that I still need to try and get video.
Short version is it's an ABS jet trainer design with reasonably good stall characteristics and great flight characteristics but doesn't have a ton of excess power. Landings require a bit of finesse to keep it from bouncing. I originally intended it to be grass capable, but I'm not sure it will actually end up that way, so you do need a runway.
Designing a 3D printed plane from scratch isn't really too difficult. You need to be decent with CAD, but otherwise the biggest challenge is controlling weight and realizing that you really do need to print almost every part with a single wall and next to no infill.
telnar1236
Almost forgot, I also have a laminar flow wing sport jet design, although it is a bit tough to hand launch and probably could do with a gyro - otherwise flies great too and you can give it landing gear like the Falcata though it lands a fair bit faster.
Benefit of this one is you can print it in LW-PLA too
telnar1236
What software do you design in? (fusion right?). Also, the Saab 105 became a 70mm correct? When you say decent with cad, how decent do you mean?
Thanks for all the help!
Yeah, Fusion 360. Yeah, the Saab 105 became a 70mm and I mostly gave up on further developing it since it needed such a deft touch with landing to stay upright and the performance wasn't worth the effort to keep updating it - in many ways the concept for it became the Falcata which is able to get away with a much lighter setup in the same size airframe thanks to the more efficient ducting.
The better you are in CAD, the better the plane will turn out looking, but you can start with pretty basic skills and work from there. At a bare minimum you need to understand how lofts and extrudes work and how to make sketches. You will also get better at CAD in a hurry by designing a plane - the best way of learning is doing. And to make a nice flying plane, you just need some very basic skills.
