Hi all
I just finnished my tricopter build, but now I got a huge problem that I hope some of you can help me with.
1. all motors runs when using the throttle, but won't change speed if I use aileron & elevator.
2. If the servo is connected to the control board it won't work, but if the servo is connected in the Rx it works fine.
3. if the settings on the control board yaw, pitch & roll is not at factory setting on nothing works.
And I think it's strange that I don't have to arm the control board to get the motors to run, and I can't disarm the board, I have been following almost every guide on tricopter control board setup there is on the internet and nothing works, and I have placed the wires as every guide states they should, i'm out of ideas of what's wrong, i'm starting to think that I have recieved a faulty control board from hobbyking.
My setup is :
3 x Turnigy DT750 motors
3 x Turnigy plush 30 Amp ESC
1 x multi-rotor control board V2.1 (the green one)
1 x Power HD-2213MG Digital servo
1 x 35 MHz Tx & Rx
All the elektronik is bought at hobbyking
I hope that one of you can help me with my problems, or maybe confirm that my board is faulty
My setup is :
1 x 35 MHz Tx & Rx
