Ok, so let's observe a REAL Dauntless for a minute. As you can see below, the gear sits INSIDE of the wheels but they do NOT extend to 90 degrees. It is sort of pigeon-toed or something but that is how it works. You can clearly see on the left the the axle for the wheel sits at an angle less than 90 degrees. So, to accomplish this, proceed to the next image.
This sort of tells the whole story. I used 85-degree retracts, but the supports for the mounting also have another few degrees to get the oleos closer to the top of the wing. This allows the wheels to sit more flush with the bottom of the wing when retracted as well. Note that the oleo, when compressed will never allow the wheel to contact it as the top of the wheel will always remain the same distance from the oleo. I want to note that I did have to do a few hours of custom work for this. The retracts take a 6mm pin and the oldeos originally accepted a 5mm pin. I had to drill them out as well as drill and tap new set screws. The oleos were about 6mm too long so I had to cut the ends off, along with the original tapped holes for set screws. Further still, The axles needed to be bent so I used some 5mm rod I had and bent the angle to get the wheels to sit right on the ground to match the image. I had to then enlarge the hole in the oleo to accept the 5mm axles and those originally were 4mm.
Here is a head-on shot and from a slight angle it's about right to match the picture above of the full scale version. The image parallax is terrible here. I assure you there is no toe-out of the wheels but slight toe-in.
So, I ran the wires up to the wing root and put small holes there to snake the wires through and completed them with a y-adapter.
To keep things tidy, I used a couple of plastic hold-downs I had in my box. These used to have nails in them that I removed. Sanded the bottom and a couple drops of CA hols the wires in place so nothing sags or snags.
So, I think the only other thing here is that I would like to dress up the nose a tad. The majority of images I've found show no spinner. I'll try printing out my Corsair spinner and see how that looks. From there, I'll move back to the Corsair to wrap things up. If there is time, I'll come back here to work on the bomb drop.
