Help! I screwed in the motor to my power pod and now my motor doesn’t spin right anymore even if I unscrew it from the power pod
Nick Makos
I just bought a mini Guinea speed build kit and I made the power pods about one of the motors that I screwed in has a rough spot now where it won’t turn properly
Vimana89
Not quite sure, maybe you used a screw that was very long and it jammed the motor up? Only thing that's coming to mind without much knowledge of the situation.
Could be a metal fragment. May need to take motor apart to find and remove. The choice to return or repair is up to you.
basslord1124
I'd check the long screw thing first.
I have removed metal shavings from inside a motor too and it can cause a similar problem.
  • Like
Reactions: FDS
