nhk750
Aviation Enthusiast
I have kind of looked around and have seen a few ideas. But, has anyone tried to scratch build a balsa style plane out of foam board. You would probably still have to use some plywood and hardwood in some areas, but the wing formers and such could be built out of Adams foam board and then covered with Mono? It would be easier to precision cut the pieces and also a lot lighter and you could use hot glue instead of CA in most areas?
Winter is coming and I was thinking about doing something cool...I did see a guy in the UK using ceiling tiles to build planes like balsa building.
