Techinator
So I know I got into the OSD game 2 years late. I just upgraded my old graupner radio to a taranis Q x7. At the same time of swapping out receivers I am putting in my first OSD. I have a naze rev 6-------OLD! I was putting the D4R-II on -,+, and PPM/1 and the telemetry wire on pin 8 as a soft serial. I have the osd going to uart 2 on pins 3 and 4. When I arm the osd stops working, when I disarm, the taranis looses all the telemetry info. Then, before it'll do anything I have to cycle the power. When I disable the uart for the osd it works again. That doesn't work the other way around. The OSD just won't work. So I think I want to replace the FC anyway, it's just outdated. The FC that I think is best suited for how I have everything set up is the Lux v2. I just want to be 100% sure that I will be able to use telemetry without replacing the D4R-II (with PPM) I already have as well as the extra uart for my osd. It would also be awesome if I could figure out if the naze can run an osd or is it really outdated.
Thanks!!
Thanks!!
