FirthColin
I connect them to the ESC and they beep doing be be be showing that they are connected. However, the arming sequence doesn't work and the motors don't turn.
Specs
Receiver: FrSky X8R
Remote: Taranis Q X7
Flight controller: Naza M Lite
ESC: Cicada 4 in 1 30Amps
INFO about current situation:
The receiver and remote are correctly bounded and you can see a solid green light on the receiver. The flight controller has been connected to a computer and you can see on the Naza assistant that when you move the remote's levels there is a reaction so everything seems to be set up correctly using the S-Bus.
I have bypassed the flight controller connecting the receiver and ESC to the power supply and a dummy servo tester got the motors to turn so they're able to receive a signal and move.
If anyone has any idea about what's going on, it'd be very very helpful to let me know so I can test it out and reply with the results.
Thank you!
Specs
Receiver: FrSky X8R
Thank you!
