I'm new around the FT Forums, here's my EDF Afterburner:
HB Stratos
Hey there everyone! I finally got a FT Forums account and I thought I'd start it off with some pictures of the Afterburner I'm currently working on. It features some quite substantial improvements over David's design and is almost flight ready.
[SPOILER="Images:"]
Picture take during first igntion at 50% throttle
Ignition system test
Afterburner at max throttle and 50% gas, this test was made during a bright day so the flame is not very visible
[/SPOILER]
Flitedesign 3d
Very nice afterburner. Are you using a stun gun module for the ignition? What are the substantial improvements that this design has over the David's one? I have also made an afterburner lately, but it is not ready yet. I have to put the heating coil behind the burner, now it has an electrical heater. Also I dont have an ignition since I can't get stun gun modules where I live. Im going to try to use resistor wire coil.
HB Stratos
@Flitedesign 3d I also can't get a stun gun here, I am using this (can't find the link, just a cheap HV generator from china, stun guns are FAR too powerful). Don't try glowing resistors, this just won't work for anything bigger than a 50mm edf.
Improvements on mine are:
  • using a heating coil directly in the flame
  • using a butane/propane mixture as gas because it takes less energy to get into gas form
  • not using part of the eflux ring - which is directly connected to the motor - as a pole for the HV igniter (This is what most likely killed the afterburning viggen)
  • not using a electrically heated coil, saves power an is not required in my testing
Currently I'm still looking to get a 70mm 12blade EDF to upgrade my testbed before I implant that design into a FT X-29, my selected testbed
Flitedesign 3d
Sounds really good! Keep us updated when you build it in the jet!
