Chriexpe
I'm new to DIY and was thinking about building a long range FPV, I was looking for some frames on Aliexpress and found out this Andy hd8 350mm, wich seens a pretty good option for FPV as there will be no propeller in front of the camera, and if everything go right I would use a gimbal with some action cam, I know, It will become quite heavy but I would be using some 6000mAh+ battery so I could get a smaller one, but anyway, the only problem that I see is that this frame use DJI Mavic Pro motor, and I haven't found any other info about it (aside some project where the drone got absurd flight time with same motor).
Or should I get a XL9 390mm frame and some 2306 motor (or smaller) and maybe get better results (and yes I would also consider a gimbal)..
Aside from de frame and motor, I would use f722s control module with 50a ESC, GPS M8N w/ stand, Frsky Q X7 with r9m module and r9 Slim+ receiver, and the VTX transmitter I was thinking about this 5.8g 1W iFlight, but I'm very doubtful about the claimed 10km+ range considering the frequency that it operates.. And the camera would be anything with 1200tvl or more.
