Wilsonman, great job on the rubric, but what if the aircraft we are building does not normally have an airfoiled tail? Will that apply the same way that aircraft without retracts/weapons will?
You get off easy
That is exactly right. You are in the wrong climate for itBlue, Pink Green...can't find any of them at my local hardware storesAll they've got is the heavy yellow crumbly stuff with aluminum on the outside and the white Styrofoam. I've seen a very thin flexible blue foam but it comes in rolls not sheets and isn't really suitable for building. I guess the stuff people use for building planes just isn't used for insulating houses here in the desert.
What? Rivets? Who DOES that?!?
After reviewing the rubric I feel totally unqualified. But, that's not going to stop me!
Jhitsma, Outerzone has a plans set for a 6/6a under the seaplanes category. There are floats on the plans, but it could be easily converted. I know the 6 isn't quite a 7, but they do look pretty similar, so if one was ambitious enough they might be able to get creative and end up with an RV-7/7A
Wilsonman said:That is exactly right. You are in the wrong climate for it
Wilsonman said:...Its building season. USE IT!
I'd love to build "for real" some day (Not that there's much chance of it ever actually happening at this rate.)
Not with that attitude you won't. Sorry, just coming from a long time EAAer. (I haven't built anything either, so take it worth a grain of sand)
Quick question: would a scale heli build be permitted? I only ask because in your first post it specified Airplane
Well dang... clearly I've been out of the loop the last week. I am in! I have several designs in mind for submission. We shall see which one i Pick. Definitely thinking a British Warbird![]()
