flyingkelpie
How sad. I suppose you have those days. I had one of those days a few days ago. (see my post above)
That happened to me too with a 70cc plane... I learned the hard way never to trust a miracle switchWhat happens when the switch controlling all electronics on board decides to quit working running nitro.
Straight in about as tight as she could go engine just a screaming until the sudden stop from about 250 feet up. There is a nitro engine on the front about 4 to 5 inches down in the dirt. Power and torque.
View attachment 184882 View attachment 184883
What happens when doing an inverted high speed pass......flying inverted down is up and up is expensive.
View attachment 184884 View attachment 184885
Both on the same day should of stayed in bed I think.
Damn. Reminds me of a club member who somehow thought putting 6 high voltage servos worth of amperage through a tiny switch was a good idea. Resulted in his very expensive turbine model looking like this but more burnyI was cruising along, everything was fine and dandy until all of a sudden it dove into the dirt. Turns out the power switch failed... View attachment 184895
Sounds fun! Our switch had a sketchy solder joint hiding under some heat shrinkDamn. Reminds me of a club member who somehow thought putting 6 high voltage servos worth of amperage through a tiny switch was a good idea. Resulted in his very expensive turbine model looking like this but more burny
I was looking at rc aircraft power switches recently and one specified "fails to the on position" or something similar. I don't know how they do that, but it seems like a good idea to have a switch that won't kill the plane if it decides to die.Sounds fun! Our switch had a sketchy solder joint hiding under some heat shrink
Is that a BluCub in the background?
It used to be a Bird Dog. It's no longer with us.Is that a BluCub in the background?
How does it fly? (I'm guessing it does )
I never triedHow does it fly? (I'm guessing it does )
