Is the blunt nose Versa just for pusher setup?
flyboy320
Can you use, or is it recommended to use the blunt nose with the Versa wing if your planning on a tractor setup, or is that really only for the pusher setup so you can get the correct CofG?
Bricks
No reason it should not work, if you can get CG right.
