jd7792
When modifing an electric system on a plane with the intention of increasing the size of the motor is it possible to use an ESC that is too big? For example if I want to change a Bixler's motor up to a 2200Kv motor when the Bixler has a 20Amp ESC as standard, is there a problem with using an ESC that you have lying around that is say 40 or 50 Amp?
Will the ESC cause any problems?
