97tj-neil
I built a FT Bushwacker over the weekend and went with the aileron and flap option. All appeared well when I tested my servos on the bench with a servo tester, so I went ahead and glued up the wing. After it was all built and I was adjusting throws, I started having glitches with the flap servos. I had to cut some access holes in the bottom of the wing to remove the servo leads to troubleshoot the issue. Here is the diagnosis.
1. The problem is intermittent (lead me to believe it was a bad servo wire, bad Y-cable, or bad connector). I tried multiple Y-cables with no change. Moving or wiggling the wires had no impact. All connections appear to be fully seated and no damaged terminals after visual inspection.
2. Sometimes the flap servos will move on their own, with no input from the radio.
3. Sometimes, they will not work at all. When this happens, the other servos connected to a servo tester stop working as well.
3.Eliminating the Y-cable fixes the problem, even though the same Y-cable works just fine on the ailerons. This requires using a separate channel for each flap servo.
4. With each servo on a different channel, if I use a servo extension cable, the same problems return.
So now, I have each flap servo plugged into a separate channel on my receiver (gear and flaps). I mixed the channels on my radio so that the gear switch drops both flaps. This works, and I learned a few things about programming my radio in the process. However, not having any extension cable makes it a challenge to get everything connected and the wing strapped down.
Do any of the gurus on here have some advice for me?
Just for fun, here is a pic of my plane.
