Very simple and easy to use. Its a cherry switch basically. You can choose normally open or closed just like any other cherry switch. No electricity is needed to run the switch, it is a mechanical switch. Meaning it uses the negative pressure or lack of to activate the cherry switch. It can handle up to around 5amps thru the cherry switch itself so if you have more than that you also need a relay.
In my case i cut the positive 12v line that was going to my pump and placed this right in the middle of it, just like an on/off toggle switch would go. Than its just as simple as running a vacuum line from the other end of the switch to your vacuum system to monitor it just like your mercury guage.
IT has an analog dial you adjust to get the vacuum you want and the "range" it drops down to is not adjustable. At the range im working at its about 2" of mercury drop before it activates.
You can see the dial nob on the left of the pic below.
https://store.acpsales.com/products/3297/vacuum-switch
