Need a bunch of right thrust. ( couple of washers under engine mount so it faces right noticeably) still will attempt ground loop if you slam on full throttle from a stopped condition.
Both wings should be the same amount of straight relevant to flight, generally the upper one needs to have a popsicle stick at the trailing edge so it stalls last. Stops the death dive sinto dirt mostly.
Rudder angle doesn't do much other than look bad, but not facing the flight path causes it to turn. if the elevator was crooked also then you get rudder effect pulling up. Look at V tails. I suspect you stalled and P factor spun you but it could have also only stalled on the inbound wing if it's crooked....
Jennies were also known to be a handful on the ground because of teensie rudder syndrome. They had a skid to help keep the nose pointed the right way.
Finally, work your way to first flight by adding power in small increments. Handling issues will show problems you have in flight. Don't want to be on the sticks hard and fast while figuring out how it handles
