Help! Junior Telemaster - landing gear dimensions?
I'm just finishing up my scratch built Junior Telemaster (Outer Zone) and I think I've made the landing gear too small. Would anyone have the dimensions for a landing gear for the Junior Tele?
I may "wing it" (pun intended) and come up with my own design but if anyone has built a landing gear for the Junior Telemaster that would like to share the dimensions, that would be great.
Here's some photos :)
~Cheers and happy building
Figure9
View attachment 161196 View attachment 161197
Nice build! The gear looks good to me. Are you concerned about wheel size or the leg length? I made wire gear for my ‘Bloody Mess’ that work well. All I did was rotate the prop to vertical & determine how much I wanted it to clear in 3 point position. Other than that one might want the prop to clear in a fuselage level position, obviously so the prop remains clear if you lift the tail on take off or do wheel landings. I like your idea to use your own design. I 1st used hot glue for wheel retention, didn’t like it because the wheels bound. Tried FT retainers but they didn’t hold on the the axle very well. Finally, I tried wooden beads hand drilled to a tight fit & that worked.
Great graphics!
Thanks @Figure9 - yes I did as you mentioned about clearing the prop. Just concerned that it isn't wide enough.
I had a thought, what I'll do is measure the one on my Senior Tele and scale it down. I'll use the fuselage width as a guide.
Oh thanks about the graphics, I have a Silhouette vinyl cutter but was a chore to position it. I'm now working on the Tele 40 and plan on making the same graphic for the wing.
Figure9
In the wee hours of the morning, I came up with a design for the landing gear. I plan on making it with 1/8"X1" aluminum.
This will be for the Junior Telemaster but maybe someone will find the measurements useful, my inspiration came from https://grabcad.com/library/landing-gear-for-rc-aircraft-1
Spring design 1
Spring design 2
Nice drawings, I like what you have there. I wonder if the aluminum would be strong enough without the spring system? Is that aluminum in the pics you posted?
#6
Hey thanks. Yes, perhaps it will be strong enough with out the spring. I'll give it a try.
I find it handy to have a printed template to get the angles correct.
