Junkers Ju-288 Scratch Build (German Experimental Schnellbomber)
What should I build?
  • Total voters
    16
  • Poll closed .
voyhager3
I’m going to start building my first twin engine plane very soon, but I don’t really know what to start with. But I have narrowed it down to 2ish things.
A- JU-288 (medium/heavy bomber, luftwaffe)
B- Expedition (twin engine 1.5m explorerish, will have some cool features down the line, and swappable)
C- You decide, but I’ll probably go with whatever of the first 2 is better unless C wins and I like the idea that has the most likes)
Leave your ideas for C in this thread if you vote for C, and stick around because I might need help later down the line
(I might do whatever I want, but I probably won’t)
Poll closes in a week
b-29er
Dornier 335?
I can't wait to see what you come up with. (And fly!)
I expect you'll find a twin is absolutely no different than flying a single engine plane. I think at this point I've built & flown more twins than singles. The only thing that some builders are hesitant with is wiring two motors and setting up diff thrust the first time, but it's no sweat at all. I love twins because it gets the motors out of the way and I have all that space to position the battery wherever I want. And forget about needing a rudder. And two motors always looks cool, even on an otherwise ugly plane! :D
voyhager3
Thanks! One question tho, do I need a cw, and a ccw spinning motor/ prop for a twin?
The motors, no. I just couldn't wrap my head around that at the beginning. Apparently a brushless motor somehow doesn't have a specific direction; It works equally well either way. But the propshaft is threaded in only one direction. Some brands will have a CW and CCW thread but it seems that's rare. You just get two of whatever you want, and the direction of spin just depends on which of the three wires is connected to which. If you want to reverse it, just switch two wires. You do need CW & CCW props. Thanks to drones there are just as many pairs of props available as just single ones. Don't worry about putting a prop on a "backwards" thread on one side of your plane. They're tightened with self-tightening nuts and that's enough to hold the prop fine even on the wrong thread.
Some people will get all technical and tell us how on these little models or on certain full-size aircraft counter-rotation isn't really necessary or isn't used, but why the heck would you spin both props the same way?! Silly. Nonintuitive. Do it the obvious way. Sorted.
voyhager3
Ok, I just didn’t want to have a prop and stuff fly off to who knows where when I have a cw motor spinning ccw and the prop flies off. Thanks the the clarification!
Test Fly RC
How about a Gruman Goose!
SlingShot
Maneuvering With Purpose
Can't go wrong with a B-25.
