IBeHoey
The Warranty Voider
over the weekend and wow, it was a doozy. I gotta say, there's no better feeling than doing a bunch of work on something, and having it work on the first try. In hindsight, I should have snapped some pictures before I clobbered it in hot glue but, oh well, it works!!
Has anyone else performed this mod on their 9X? For me personally, the most nerve racking part was working on the DJT RF module. It required making a fine little cut on one of the (1mm in width) traces, removing about 2mm of that trace, and then re-bridging it with a 1k SMD resistor and the RX wire which will connect to the RX pin (#5) via a 470ohm resistor.
I still need to interface the D8R-II receiver with my FC board in order for it to display the data but the FrSky ER9X firmware is pretty cool. I imagine once I get everything up and running, this little mod is going to be awesome.
For anyone else thinking about performing this mod on their 9X, please note, it's not for the faint of heart. However, if you have a steady hand, patience, and a fine tipped soldering iron, it's totally doable and well worth the effort. The only drawback of performing this mod, aside from the tedious soldering, is that, in order to make use of the 2 unused RF pins, #2(6V DC) & #5(RP OUT), you have to isolate them from the internal circuitry. This method is nice in the fact that in doing so, you won't have to worry about running a cable from within the TX to the back of the DJT RF module. Which makes for a clean install but, from this point on, if you want to use any other RF module, for instance the old bundled FlySky module, you'll have to also isolate those 2 pins from within the RF module, or else you'll run the risk of releasing the "magic smoke".
Here are a couple links to the tutorials that I followed.
http://openrcforums.com/wiki/index.php/9x_Full_Mod_Telemetry
http://openrcforums.com/wiki/index.php/9x_Full_Mod_FrSky
http://openrcforums.com/forum/viewtopic.php?f=23&t=430
Once I get everything up and running, I'll post a follow up with some screen shots of the data being displayed on the 9X.
