Kamikaze pilot?
How do you do that? I try reducing my throttle as i corcle down for landing and sometimes the plane wont react anymore. Trees have eaten it that way
You just increase the throttle on the turn just enough to keep from stalling and to keep it responsive, but not enough to increase speed if you can help it...If you actually make your descent on the turn it will keep your speed up and you can descend thus killing to problems with one movement!
Quackerhonk
Oh so it's not a digital transmitter? I was going to say if you do have a digital one you can just mix one of your switches to cause your ailerons to act as flaps as well ans ailerons....
Yeah, i have some flyskys so i could swap recievers but i dont think thats worth it
Have you ever gotten a horizon hobby plane for example? If you have, then what do you do
No I haven't but I want to get some RTF planes to review sometime....I know @Mr Man has got a couple from Hobby King... All you have to do is to take out the Y harness of the ailerons and then plug one into ch 1 (This is one Flysky) and then one into ch 5 then mix ch 1 to be the master of ch 5 and then use another mix to have ch 6,7,8,9 or 10 to be the master of channel 1and and then do your last mix as the same ch 6,7,8,9 or 10 to be the mast of ch 5 so that when you flick the switch it will deploy your flaperons and when you move the ch 1 it will move ch 5 (You may have to experiment with the negative and positive throws to get the ailerons to line up right and move the right directions.....I should really do a video on it sometime! I hope I explained it clearly! 😂
Quackerhonk
Thanks!!
