Kamikaze pilot?
No I haven't but I want to get some RTF planes to review sometime....I know @Mr Man has got a couple from Hobby King... All you have to do is to take out the Y harness of the ailerons and then plug one into ch 1 (This is one Flysky) and then one into ch 5 then mix ch 1 to be the master of ch 5 and then use another mix to have ch 6,7,8,9 or 10 to be the master of channel 1and and then do your last mix as the same ch 6,7,8,9 or 10 to be the mast of ch 5 so that when you flick the switch it will deploy your flaperons and when you move the ch 1 it will move ch 5 (You may have to experiment with the negative and positive throws to get the ailerons to line up right and move the right directions.....I should really do a video on it sometime! I hope I explained it clearly! 😂
Very good summary, much better than I could do 👍
