Why would a person buy a prop balancer? I never used one. What's the purpose?
Gravity Folks.Hint: the heavy side tends to be on the bottom
A prop balancer is great to balance props to get rid of vibration and even better to balance a prop spinner combo. I've only had one spinner that was even close to balanced.Why would a person buy a prop balancer? I never used one. What's the purpose?
I wonder if it would make a bigger deal to balance your props with a faster spinning motor.Cast things like your molded prop have density differences. Kinda a "bonus" from making cheap props fast. When you spin an off balance thing really fast, the off balance part gets heavier (technically) and starts to shake things. Shaking your electronics is a classic way to kill your electronics right now by mechanical fatigue. Having such a failure, if it doesn't let the magic smoke out and cause an inflight fire, generally causes your plane to explosive disassemble on ground impact which tends to make you unhappy.
Balance prop: be happy. Don't need a prop balancer purchase, you can build one with a needle and a something to stand the needle.
Yes, definitely. But I like to run Apc props, which are pretty well balanced.I wonder if it would make a bigger deal to balance your props with a faster spinning motor.
I like the Gramfan 9x6 for my bigger planes....Yes, definitely. But I like to run Apc props, which are pretty well balanced.
I like apc props if they’re 6in or less, (unless it’s a 12x6). But for my swappable’s, I run Amazon 10x4.5’s.I like the Gramfan 9x6 for my bigger planes....
Because they are cheap and are the strongest props I have found so far! Strength makes a big role when choose your props when you just start flying and break a lot of props 😬😲😮
I use 12x6 props on the original timber, they seem very balanced from the factory.If you're up into the big props of +12" you're going to be stuck using gasser props. Those I have never seen balanced well in plastic. Master airscrew were balanced, but afaik those aren't available any more
Balance is balance, either 0 rpm or a gadzillion. High rpm will cause more, rapid shaking therefore showing even a tiny imbalance. After I balance, I put the prop and balancer on top of my phone set to vibrate to see if it is actually well balanced
Great video L Edge!Here is an excellent video to show how to do it properly. Especially if you are looking for extra speed.
It doesn't give the max prop diameter but in the picture it looks small.You guys think this would work? it's a tithe of the price of the one in the video.
Propeller Balancer with Magnetic Suspension High-Precision CNC Aluminu | SpeedyFPV
Uses N45 high performance magnet with fixed plate made of carbon fiber board material and steel with aluminum balancing rod. Features: MagLev method was adopted on the center fixing axis to balance the tested products with zero resistance. Fit 0-80g Fixed wing propeller, marine propeller, car...speedyfpv.com
