colincolin30
HI thanks for looking.
Equipment;
Spektrum DX6I transmitter
Hobbyking controller board v2.1(Atmega 168pa)
DT770 motors( think that's the correct code -the blue motors the ones recommended)
ESC 30 amp Plush
Spektrum receiverAR6210
I have built the H Quad ( followed the plans to the letter) and having problems with my controller board V2.1.
I have flashed it twice and pretty sure the firmware (x copter configuration V4.7 ultimate) loaded is A OK.
I have a screen shot. I downloaded the Quadcopter controller manual and have tried the set up once again following the information.
Connected up the radio receiver and the 4 ESC's making sure the wiring is correct. Black wires to edge of board etc.
I have set up the ESC's but motors will only rotate if the YAW pot is set to 100%
When the transmitter is powered up I can run the 4 motors ( and in the correct rotation required)and able to vary the speed.
Now for the problem:
If i dip the quad the motors should go faster to compensate for the dip, however they do not. If i move the flight control stick, motors do not speed up.
I have gone into the setting "REVERSE "and tried reversing pitch, roll and yaw, still nothing so placed settings back to "n" normal.
So my thinking is that I have not armed it. So I powered up the transmitter connected flight controller and moved the throttle stick to the left ,held it there for the 5 seconds,still no result. Tried it to the right same thing.
I Have tried adjusting the trim, still not luck.
I have no reason to think there is any problem with the KK controller board. Pictures are attached.
What have I missed what am I doing wrong???????????
If you can given me some precise details to try It would be much appreciated.
regards Colin
Equipment;
ESC 30 amp Plush
regards Colin
