mightybubble
Evening all
I've been flying my 450 quad and tricopter l.o.s for a while now and getting pretty confident with them.
But I seem to have poor throttle control.
On a calm day ( absolutely no wind) the quad and tri will lose height pretty quickly without alot of stick adjustments.
Today I bit the bullet and went fpv with the quad.
Again it was a calm afternoon. I sat the quad for 15mins in the field while I messed with the goggles and set the osd. Took a quick los flight while the misses checked the signal through the goggles and all was good. So I threw on the goggles and took off to about 2 metre's high.
Now this is where it all got a little twitchy. I couldnt control the hover. The quad either climbs rapidly or drops to the grass. Resulting in two broken props and a crushed antenna.
My setup is as follows:
Turnigy 9x with frsky module.
450 hk quad frame
4 x 850kv motors swinging 10x6 props
4 x 20amp redbrick esc's with flashed Simonk firmware
Kk2.0 1.6 firmware
My fpv equipment works perfectly and as expected.
When flying los I can control the hover without thinking about it. But im thinking I need to add expo to the throttle while fpv'in.
Or is this something I will learn to control the more I fly fpv? And are there any tips for learning to fly fpv?
Many thanks in advance
450 hk quad frame
Kk2.0 1.6 firmware
