Hello I’m hoping someone can help me with my issue.
I finally got all the parts for my quad-copter and from what I can tell I have everything set correctly and everything is bound correctly. However the KK2.0 board will not arm and the receiver test shows 0 for all values despite the TX and RX being bound and tested using the ESC and motors separately.
System specs:
KK2.0 running 1.6 ++
Afro ESC 30amp (stock firmware)
Turnigy 9xr loaded with er9X firmware set to ppm 8ch
FrSky DJT Module
V8FR-II HV receiver
Here is what I am seeing as of right now.
The RX appears to be bound correctly and does work when not running through the KK2. The KK2 however seems to have a few problems sometimes the board will say no input from cppm when turning on to fix this I usually have to turn of the transmitter off and then back on to get that message to clear. From there I cannot get the KK2 to arm and the ESC calibration test fails since the throttle has no input. Then when I go into the settings and then receiver test I see 0's down the line. Moving the sticks do not appear make any difference.
I am completely new to the hobby and i'm hoping its something simple that i'm missing somewhere but my suspicion is that its either the Firmware on the KK2 or the board itself hoping someone can assist.
System specs:
FrSky DJT Module
V8FR-II HV receiver
