I think I've figured out the root of my issue with the CG problem, and once again it comes down to builder error...
I'm not using the frame as it's designed to be used. :black_eyed:
The frame comes with six hex standoffs to be used as landing gear, and is designed to carry a GoPro underneath on the floating battery tray suspended by the black rubber dampeners.
I'm flying with a Mobius on top instead of a GoPro, so I chose to not install the hex standoffs/landing gear nor to use the actual battery tray. Instead, I put the battery on top of the cage, which doesn't extend as far behind the hex as the battery tray does and doesn't offer the proper balance to keep the correct CG.
So I see three/four options:
1) Deal with it and let the battery hang off the cage (my main concern is that it slips out of the strap and drags the copter down).
2) Fabricate an extended cage piece from old credit card or something to give the extra support to the battery (likely what I will do for now).
3) Find some way to move the vibration dampened battery tray to the top of the cage (I think this is ideally what I would like to do).
4) Strap the battery to the actual battery tray (and add the landing gear just to protect battery, don't really wanna do this)
I've also gone with flashing Harakiri TestCode3 to my Naze32 and I removed all expo settings from my Tx. The Hex seems to be flying much better now and I'm not nearly as frustrated with this frame now that I can see the error was my own fault. :]
