Knuckle H-Quad
epic.engineering
TraceNoOne
I am also using the suggested electronics listed on the Flite Test website.
Can someone post wiring diagrams or suggestions. What wires or connectors or cables to use? What receiver and battery are they using?
xuzme720
Dedicated foam bender
See if this helps. If not, try his simple tri build video. He goes through all the connections and that is basically the same for all multi's, (except tri's which add a servo for rudder,) even if the actual components vary.
xuzme720
Very patriotic! Looks great and can't wait to see it in the air! You'll have to get some video for us.
TraceNoOne
Got mine painted. Just waiting on electronics. I placed an order for my blue wonders but have not heard from anybody yet.
Same Knuckle H-Quad video posting below.
http://www.youtube.com/watch?v=MCf-T2kvUOg
Craftydan
Hostage Taker of Quads
Got mine painted and assembled. Should have it flying this weekend.
Nice job! (I'm assuming you're planning on securing that go pro down better right? don't like camera snuff films ;) )
Either way good luck on the maiden (take it slow) and welcome to the forum!
xuzme720
Camera snuff films!?! I really worry about you sometimes, Dan...
And other times I want to ask for links! :p
Craftydan
Footage of *CAMERAS* dying!!!! Jimminy cricket, Xuzme, the directions you go sometimes . . .;)
3rdeyepro
Here is the completed quad (minus FPV gear and GoPro). I designed a Hero3 anti-vibe mount that will be going on the front. If it works well, I will have a few extras to sell for those interested.
cranialrectosis
There are some beautiful Quads on this post.
I use the same motors, same ESCs, same battery, FCB and same props on my Anycopter and my Knuckle Quad. Exactly the same parts. Both copters weigh 840 grams.
I notice that I get almost two minutes more flight time with the Anycopter and that I use less throttle to hover with the Anycopter than with the Knuckle H quad.
I have two theories on this and would like to ask for input.
One theory is that the Knuckle quad is smaller and the KK2 is making more adjustments to keep it level (I only fly with autolevel on at this point). I have tuned the KK2 on both copters and there are VERY minor differences in settings.
The other theory I have is that the AnyCopter's X shape puts only 4" of boom under my 8" props while the Knuckle H quad has the same 4" of boom but also has some 2" per rotor of the frame directly below the rotor. I think this causes the rotor to push down on a larger section of frame making the Knuckle H quad less efficient.
I mount my motors high on both copters to avoid rotors causing the booms to vibrate by creating an air pocket so the rotors are 3" - 4" above the booms and the distance is consistent between the copters.
I am thinking of re-building the Knuckle H quad by placing the center rails of the frame together (so they touch) and placing the hub on top of it so that the center of the copter is not enclosed on the sides by the 1/2" rails. This rebuild will remove all the center rails from under the rotors. Since I put my wiring and ESCs between the plates, this also allows for airflow to hit the ESCs from the outside edges.
Thoughts?
xuzme720
Twist...By taking the spread of the center rails out, you are asking for longitudinal twisting. Might be better to just use longer arms for the motor mounts.
cranialrectosis
Yeah that is my concern. I use 10" motor booms and 8" center rails to purposely cut the copter down in size and I want to keep it small. Am thinking that I may screw them together in the center to make one 1" wide center rail to prevent torque from jacking me all up.
xuzme720
If you need to keep it small for agile-ness, maybe narrow the center beams to an inch apart, to at least keep it somewhat boxed for torque twist resistance...
cranialrectosis
Thank xuzme. I'll give it a shot with an inch of separation and see how that goes.
Any ideas about why the two copters would show a 10% difference in flight times? Will the frame being below the props cause that much impact?
