Lack of thrust
TheRCFool
Super Cub Love
Our good friend Charley took a break from rc cars to join us in flying. He built this A-10 EDF and when he took it out for its maiden, this is what happened. Any thoughts?
pgerts
Old age member
1 - are the wheels tight? - Do you have any thrust when holding the plane up from the ground?
2 - are the fans spinning free? - Some (GWS) needs to be trimmed to get clear from the tube.
3 - Battery - does it give enough power. C-rating or cable gauge..
FlyingMonkey
Bought Another Trailer
Admin
I can think of a few things that would cause that. A bad battery, or one that wasn't charged all the way. It could have been an older kit, and the motors aren't strong enough to take off from a grass field. The end points on the ESC aren't adjusted, so it doesn't spin up to full throttle like it should.
colorex
Rotor Riot!
Is he too much into cars? LOL JK
Yeah, throttle endpoints, battery rating according to motor, weight of the plane, etc.
lonewolf7717
Most certainly does not sound right, he built this you say...scratchbuilt or kit? Not uncommon for folks unfamiliar with edfs to "egg" the housing a bit during assembly. If it was a edf kit and a cheaper one at that they are notorious for poor tolerances in foam mold around fan housing. Either too tight or too loose, if too tight its very plausible being new to all this he simply "crammed" the edf(s) in causing them to egg slightly thereby making the fan bind. I would remove both motors and bench test, if egging was the culprit simply remove a bit of foam.
