Landing gear for the FT Versa Wing
kcleung
I plan to buy a kit for the FT Versa Wing and build the wing in the push configuration.
However, I would also like the wing to be able to take off from ground. So which landing gear I should use and how can I install the landing gear onto the wing?
Also, in the case of the Blunt Nose Versa Wing, do I install the landing gear on the mid section?
mrwhiskers
Ludicrous speed, GO!
#2
well, if you're doing the pusher, taildragger is out. i have seen others do a tri gear setup. personally, i feel it doesn't need gear. it will add a lot of drag and reduce the speed. i will admit, it is a bit tricky to launch, but after a while you get used to it. my versa pusher doesn't have gear, and its fast and fun.
kcleung
#3
Okay..... so if I want to use landing gear, then I must adopt the tractor mode.
In this case, I will get the landing gear kit:
https://store.flitetest.com/landing-gear-kit-2-pk/
and a pair of 2.5" swappable wheels:
https://store.flitetest.com/swappable-wheels-2-5-pair/
Am I correct?
How about the tail? Do I install wheels on the tail or do I just have a pair of wire skids?
Also are there videos on installing landing gear onto FT swappable kits? I want the FT Versa Wing to be able to take of by itself
mrwhiskers
#4
what i did for my taildragger one i made a looong time ago is put bbq skewers on the bottom of the fins so they extend out about 2-3 inches. acts as a pretty good tailskid landing gear setup looks ok. at the end of the swappable power pod build video there are instructions on how to make gear on the power pod
