Landing gear (Hex Anycopter) for camera gimble
Greetings,
I have my Anycopter kit and spares incoming for my first home build Hex Anycopter.
The Hex will be used for film footage and for that I will mount a camera gimbal under the Hex Anycopter.
My question is about the landing gear I need to build for the Hex Anycopter. Do you guys have any suggestion what to use. I saw the wooden one that Flitest uses, and you can buy a lot of different landing gears from different vendors.
Any suggestion which Landing gear would do the trick and help to flight the camera gimbal?
Thanks,
Thorsten
This looks really good, I am working on a setup like this now using 2 re-trackable gears from HK.
I also found this cool how to build re-tracks.
Cyberdactyl
Misfit Multirotor Monkey
#4
I bought three of these for my tricopter. The load capacity is bit of overkill. And since it's my primary (and only) multirotor at the moment, :( I want to keep it light and no-nonsense. Once I get the quad I'm working on done I'll put them on.
#6
The Digital Servoless Retractable system are looking good. Which gear did you use with them?
Thanks,
Thorsten
Cyberdactyl
#7
Thanks,
Thorsten
I haven't put them on yet.
But I have ~26" of 5mm carbon fiber tube left over from another project. I'm thinking of turning my tri into quite a light show with my 1300+ lumen and laser module with 8" long retractable legs with LEDs inside ping pong ball foot nodes. :p
But all that adds up to around ~400g (bling) + 990g (tri). Maybe a bit to much for three DT750s with 1147s. :rolleyes::p
