Hello all,
I'm relatively new to the hobby so maybe I'm missing something but is the 20amp ESC in the lazertoyz beef package for the sipfire a little light?
I hooked up a meeter and I'm pulling 21amps at full throttle with all the supplied equipment including the prop.
The kit has
(1)1 Emax GT2215-09 1180KV 2.25 lbs thrust (includes prop adapter)
(2) 9X6 Emax props
(1) Lazertoyz 20 Amp ESC
(4) Emax Budget Servos
(1) 12" "Y" Servo Connector
(4) EZ-links ( 2 packs of 2)
(1)1300 Mah Lipo 20C discharge and 5 C charge rate
The motor specs show it pulls 24-26amps with a 10x6 and 10x4.7 so 21 with a 9x6 seems about right.
I keep hearing about the 20% rule. Should I be concerned?
Thanks,
Chris
The kit has
(2) 9X6 Emax props
Thanks,
Chris
