GliderFlyer
Sweet.Let's build a wing! Needs more ribs...
Top spars added to the center section, and the outermost rib added while the wingtip is sitting flat and before it's glued to the dihedral braces.
Gluing the wingtip to the dihedral braces and adding the outer spars - glued first to the wingtip and the outermost rib...
And then those outer spar sections are cracked at the outermost rib so they will angle down and connect to the center spar sections.
Repeat on the other side...
And then add 1/16" caps on the outermost two ribs
Almost ready to flip the wing over and do the bottom spars...
I see you are using a magnetic building board. Just one question:
What are those triangle thingies that you are using to keep the ribs perpendicular called? They look useful.
