Lessons I'm learning
dnsmith415
So since starting to build my first plane - a mighty mini corsair this week I've learned 1. It ain't easy to build these things; 2. Its going to take me an embarrassingly longer time to build than the estimate; 3. Glue? My old glue gun is a piece of junk and the glue doesn't hold together; I don't have sharp razor blades or exacto knives so cutting stuff is a nightmare. 4 My glue won't hold the model together but it sure as heck glues my fingers together! But I'm learning. Can anyone recommend a good glue? Thanks for all your help.
Flying Monkey fab
I just laugh and laugh at time estimates.
A good glue gun is a must! There are threads here about them.
Sharp blades are a must. Taste vary on these but I like good quality retractable blades, that way I can have a small blade when needed but can also extend it fully for things that need that.
...Can anyone recommend a good glue? ...
I use this glue gun from Walmart. I produces all of the hot glue that I need.
One thing about hot glue, you must let it get hot. A glue that is not completely hot will not stick adequately. I let my glue gun heat for a minimum of 5 minutes before I use it. Then I squirt out few drops then let it warm for another minute or two, just to make sure it is completely hot. I also find most people use way too much hot glue. More glue doesn't make it stronger, just makes it heavier. I thin bead is all you need.
CrshNBrn
I've burned through a couple of glue guns over the years and will second Merv's advice about warming up the glue completely and using a light touch. Cheapy glue guns are just fine, but I do like a dual temperature feature, as sometimes I'll use the hot setting (especially for large glueups needing extra time).
Can't skimp on razor blades though. Nothing worse than a jagged cut, right? My advice is to buy in bulk and save $$$.
Bricks
When it comes to hot glue sticks try and find the clearer ones for some reason they work much better for me the the cloudy ones.
For most cuts I use a cheap snap off the blade types for curves the Exacto type knives. I really should get a swivel head one for curves.
Corsair should not be your first plane to fly IF you are just getting started more then likely a disaster in the making. Don`t spend a lot of time painting it until you have flown it a few times..
I prefer Industrial, but so far for relatively quick and easy someone gifted me a green ryobi gluegun which works well but drips. Can use my smaller diameter <1/2">.. commercial 3ft sticks
Just one of those Adtechs form Dollar General will work fine, just make sure its a full sized one (y)
As for glue, i just buy this and it used to last a while!..Nowa days..Not so much!:ROFLMAO::ROFLMAO:
Mr NCT
VP of SPAM killing
+1 on the Adtech, mine has lasted for years. My favorite knife is an 18mm Olfa with Olfa blades. They seem to keep an edge longer. They seem to dull up quicker on black dtfb, anyone else seeing that?
Black DTFB is just weird. Wavy, odd thicknesses in a box, warped, paper sometimes isn't glued on or is thick/ thin
Anybody strap hone their blade.when cutting?
I use a fine stone on my Exacto blades until they are to short to be useful.
Which handle? I run some big handle blades in my #1 handle/holder but mostly the other way around because I loose the #1handle building stuff
dnsmith415
:). Yeah - I thought so. The time estimates are really optimistic. And making a 45° cut looks so easy.
I bought a Gorilla glue gun and sticks on Amazon and I think that's going to work well. So I might have that problem licked.
dnsmith415
Yea I I know one solution rarely works for everything but I bought a Gorilla Glue gun on Amazon and some gorilla glue sticks and tested it. I'm happy with the results so far. But I've heard a lot of good things about surebonder So I'll pick some up next time I'm at Walmart. Thanks for the suggestion.
