telnar1236
My first attempt at a 50mm jet trainer was not very successful and barely flew. However, my reasons for it (wanting a cheap easy to replicate jet that flies well as factory options get more expensive) are still there, so I'm designing a new version that should hopefully be much better. It's based on my successful 70mm jet trainer with some substantial improvements and obviously reduced in size.
The low horizontal stabilizer should avoid deep stall tendencies which I am now scared of after the problems of the previous design. It also uses a more stall resistant airfoil than the previous design. And the wings should be very stall resistant between the Clark Y airfoil, wing fences, small leading-edge extensions, and 3 degrees of washout root to tip.
There's nothing particularly crazy about this design, and not attempting to make it look retro like a 50s fighter should remove a lot of the uncertainty from the aerodynamics, so I'm hoping it should fly a lot better.
