Lidl Hunter build update - Potential CG issue? Help!
Bonzodog
Lidl Master
Update on progress with my Lidl RC 'Hunter'. This is my no 11 cheap foamie Lidl glider RC conversion, (build blogs nearly all on my channel,) and I think I may have a little problem with this one? Need some helpful ideas please, and not just cut off the nose of the plane! Plus other work in progress at the moment.
quorneng
Horrible to launch but how about prop at the back?
It is where the EDF is on my scale foam Hunter. Battery ends up in the Cockpit.
Bonzodog
Lidl Master
Thanks!
A bit late now as I have fitted a motor on the front end, with battery in as far back as I can get it I think a little lead in the tail will sort it. If not, version will be a pusher!
