ligbaers FTFC22 builduary
Ligbaer
50 Percenter
This is my first time doing builduary.
I have had a very long build list so I figured this would be a good time.
So my list is as such
1.STX
2.48 inch Sbach 342
3 .Grumman widgeon
4. Jetworks mirage (imo there cooler than the gripen
Other builds that are not builduary
1.sopwith pup for ff22 challenge
2.stand off scale extra300
(Will be putting these in this thread)
Ligbaer
50 Percenter
Ligbaer
50 Percenter
Step 1.Tail surfaces
I like to start by sanding the hinges instead of beveling, so that’s what I did
Now test fitting
Glued
Ligbaer
50 Percenter
Step 2. Fuselage
i will start with doublers
you put glue on one side and put them together
and then do the other side
now your supposed to glue the doublers to the fuse but the issue is that there’s no markings on the plans on where to put them, so what I did is measure 5 millimeters from the top and make an outline like seen below.
now I can glue them.
but turns out I should put them on the bottom cause there not as big as I thought.
rest of fuse is b folds
I made a little bulkhead
image.jpg image.jpg L
the back has some taper
additional backends
And fuse is complete!
SSgt Duramax
Step 2. Fuselage
View attachment 214927 View attachment 214925 L
additional backends
It goes together pretty quick. I think you will be impressed with how easy it is to fly. I built a micro version, but I am also planning on building a 125% version at some point too. Looking good so far.
Ligbaer
50 Percenter
Thank you.
I also want to ask (maybe I didn’t see on plans) but where did you put the servos on the micro Kadet?
Paracodespoder
Not a criticism just a suggestion, if you can, get a sharper blade.
Seemed to me that the paper and foam are tearing on your cuts, a sure sign of a dull blade. My first several planned I had the same issue, and when I switched to a sharper blade it got way better.
Apart from that good job and good luck 👍.
Ligbaer
50 Percenter
thank you for the suggestion, I’ve been meaning to get a new blade for a while.
Ligbaer
50 Percenter
Part 3. Wings
I decided to do a armin wing because I don’t like the way ft wings look with the scores in them.
I’m gonna start with spars. Instead of a box spar I just took pieces of foam and stacked them till they were the height of the box spar on the plans ( I didn’t feel like doing long score cuts)
Then glued were they are supposed to go
Done with one wing and made another (I messed up one wing and then ran out of white foam)
Taped
Glued
wings done!
Baron VonHelton
Part 3. Wings
) View attachment 214956
) View attachment 214959 View attachment 214960
Taped
Glued
wings done!
Ok, serious question:
The folded wing......How difficult is it to get right, and how much weight does it add?
:unsure::unsure::unsure::unsure::unsure:
Pieliker96
+1 for the sharper blade, it makes a world of difference.
You can also resharpen the one you have - I've started doing that to all the blades I have - saves money and keeps e'm out of the landfill.
