Tench745
I've posted some pictures on the Flite Test Fans Facebook page of this little plane and the amount of interest shown has been startling. With over 100 "likes" and multiple requests for plans I figured I should post a build thread and plans for the little guy.
(Plans here: https://forum.flitetest.com/index.php?resources/lil-phil.377/)
I should start all of this by giving credit where it is due. This design is based on a balsa plane designed by Hilmar Lange called the Phat Phil. I took his plans, printed them out at 80% size and modified them as necessary while I was building. I've decided to call this version the "Li'l Phil" in honor of the original. Aside from the reduced size, the largest changes were eliminating the landing gear and modifying the size of parts to support 1/8" XPS foam sheet construction.
The construction of this model isn't particularly difficult, but cutting the foam sheets requires more tooling than a beginner modeler might have.
I have a jig I made for cutting foam planks. It's relatively simple, just a pair of stops to hold the wire and a pair of shims to hold the wire at the right height. For this project I shaved down a piece of 1" XPS foam into 1/8" planks.
That's it for tonight. I have some work to do to finish up the plans so I'll be posting those with some more construction details as I go.
