@Merv introduced me to a super little micro FC the FlyinRC F4 wing Mini controller that has a HDFPV connector and even comes with ArduPilot on it. This thing looks PERFECT for my HD FPV Nano Goblin build. I have been planning all along for this build on using a SpeedyBee F405 Wing Mini, but it always seemed like overkill for the super basic setup needed for the Nano Goblin. Previously I had though about using the Omnibus F405 Nano V6, but it comes up short on the Serial port side. I could either do OSD or GPS, but something had to be sacrificed. Then came the FlyinRC FC. PERFECT. Mine showed up today, and as always, when I get something new that I haven't used before, I find out what firmware and settings it came with so it can always be put back exactly like it was from the manufacturer.
Knowing it came with Ardupilot, I hooked it to my PC, fired up Mission planner, and looked at the log file:
3/29/2026 1:25:54 PM : IMU0: normal sampling 1.0kHz/1.0kHz
3/29/2026 1:25:54 PM : RCOut: Initialising
3/29/2026 1:25:54 PM : MatekF405-TE 001C003B 33354715 35323532
3/29/2026 1:25:54 PM : ChibiOS: 88b84600
3/29/2026 1:25:54 PM : ArduPlane V4.6.3 (3fc7011a)
3/29/2026 1:25:52 PM : Initialising ArduPilot
3/29/2026 1:25:52 PM : Beginning INS calibration. Do not move plane
Then saved the config to a safe place where I could go back to it if needed.
So, it is a Clone of the Matek F405-TE, and running the latest stable release of Ardupilot: V4.6.3
MUCH smaller than the SpeedyBee. It's just a single board. Nothing complex. Will use the ESC BEC to power it, and the FPV will be powered directly from the battery.
Cheers!
Cheers!
