Little Harry Potter/ Quidditch in the gym anyone?
Madspadder
Just printed plans for a 50% Harry potter based on Avtims Firebolt. You can get the plans here: https://avtims.com/avtims-firebolt/ The plans are on 8 pdfs which when reduced to 50% each page will print on 2 letter size sheets of paper. The plans are meant for foamboard and built using Flite Test techniques, so there will be some changes from the plans to downsize Little Harry. I plan to use as much 2 mil foam as possible and use 6 mil where needed. Not sure how it will work but should be a fun project. Hopefully I will get it finished soon, but with Christmas around the corner plus working on a couple more Buzzard Model kits may be after the holidays.
Madspadder
Started building. Pretty simple build so far. I am adding 6mil to the legs and broom. I laminated 2 mil for the wing and glued some tissue paper for a cape effect when flying. I don’t think this will effect flight significantly, but thought it would add to the look.
