Live Propellor on the Workbench
toryander
I've heard it said that you are supposed to take your propellor off when working on your plane indoors. I always thought that sounded like a good idea, but I never did it. I had my FT Tutor with its 9" propellor on my workbench. I connected the battery to do something or the other. Of course my tx was right at my elbow which then knocked the throttle (throttle cutoff not engaged). Now I have three good gashes in my forearm and a blood stain on my plane. I asked for it. Carelessness is not good for you.
randyrls
Randy
I hope you heal quickly.... Like many "accidents" this was not a single failure point but a string of failures. I've trained myself to always use the throttle cut (TC) when not actively flying. Before flying: TC on, turn on transmitter, Throttle down, plug in plane battery, test controls, carry plane to flight line, put plane down, turn TC off, fly. After landing: taxi over, TC on, carry plane back to table, unplug plane battery, turn off transmitter. Workbench with plane on it, props OFF! I also have a switch (extension cord) that I connect between the battery and plane. Easy to shut down power.
I have a Bronco made as a twin. It scares the bejesus out of me to reach between those meat eaters to plug in the battery, so I added a "kill" switch at the tail end of the center section.
toryander
"I have a Bronco made as a twin. It scares the bejesus out of me to reach between those meat eaters to plug in the battery, so I added a "kill" switch at the tail end of the center section."
I like it!
31SamCoMi
That is something I have against getting into the hobby with a standard non-programmable 4 channel radios. They do not come with a throttle cut switch and people getting into the hobby (who generally start with 4 channel) are more likely to make mistakes.
