Matthew Sanders
So I'm still relatively new to flying, but I can get a plane in the air and keep it there. I just recently bought the LongEZ speed build. I don't know what happened but I'm pretty sure it had to do with thrust angle. My CG was perfect, I know this because I threw it around with all electronics in and it glided beautifully! But when I did thrust tests, the nose wanted to pitch down. (I tried to add a video showing this, but I don't know if it uploaded) I tried moving the power pod, but it still pitched down. It eventually worked after a few crashes (and cosmetic damage) but I don't know what the heck I did to fix it. All I'd done was something unrelated to the power pod (if it matters, my Dad convinced me to try again, and powered my TX back up) so I have several questions.
1) What did I do, and can I do it again? 2) have any of you had similar problems and have solutions/advice?
I'll add some specs if they matter. TX- FlyskyFSi6, power pod: power pack A, Battery: Tattu 850mah 11.1v 2s Li-Po. Expo: 30%(recommended)
It would be extremely helpful if any of you have advice or solutions. As of now, I think I'll put the electronics back in my tiny trainer. That is way more relaxing. Thanks!
