So a few key pieces of information are missing such as do you have any experience building / flying quads (if not learning to fly on something smaller and less likely to break when you crash is a good idea).
If you are experienced then things you need to consider are how heavy is your camera equipment, frame etc going to be. This will help guide you to a prop and battery combo that gives you what you need.
DamoRC
Thanks for your answer.
Yes I have experience in building (but I'm not a professional mostly in flying, but the electronic/mechanical buildig is not hard for me). (I think it is much easier to put one good working quadcopter together then a 3d printer from scratch.) But I think flying is always learning a new, like motor riding
And yes in acro mode I have much to learn
I have some quadcopters
the strongest is an fpv racing 3d printed firefly with 2300kv motors, 5040 kingkong props 2200mAh 4C battery, ominbus f4 v3 FC. (First I want to build the camera quadcopter but a (more experienced) friend of mine said "first learn to flight" (and the "things like dji is not flying instead you just moving a camera in 3d") , so I made firefly, and crashed some times
But I have lot to learn.
For frame i want to use Carbon Fiber Tube Cylinder ID12mm OD14mm, what I like is now this layout (couse its easyer to transport):
https://www.kickstarter.com/projects/wiggly/easy-drone-xl-pro-longest-flying-quadcopter-on-the
But If U know better (modular design ) then please let me know.
Weight:
What i have now it is a 4k action cam it is just 74g, and an older nikon d80 (but it is heavy so I dont think it is good for that)
later I need to buy stg. maybe like a fuji x-t20 with a wide lens is about 560g, but first I want to use my existing 4k action cam. And some gimball about 108g. And the electronics, ESC, FC, raspberry, etc....
So finally about 700-800g to carry. It is good for me maybe if I can replace the props when I just use the action cam, and replace when I use the heavier stuff.
What I dont found yet, is an opensource active tracking like functionality is available now for diy quads?
regards
HyGy
