Longshot is finished!
Today I woke up and started to build. Now at almost midnight, I have finished the build! It's finally ready for the maiden.
Here's how the rest of the build went:
First I started by making the holes for the pushrods with a file.
Remodeling the servotray. I made some supports where I glued the pushrod sleeves into.
Test fitting the servos and tray. I had to go with servos like this since I couldn't get enough space for the servo arms if the arms were facing outwards, they would collide with the pod wall.
More testing and fiddling. I pushed the pushrods through the pod and glued the sleeves into the tray.
After that I put the tray into its position and with the help of magnets dropped some CA inside and glued the sleeves into the sides of the pod. (the pictures are not in correct order for some reason, I made the hole for the aileron wires earlier).
Glued the servotray. Then glued the servos in.
Fitting all the wires and centering servos.
I just used clear tape to attach the pushrod sleeves to the boom.
Rudder coming together. I used 5 minute epoxy to put all the control horns in place.
Here is the hole I made for the aileron servo wires.
Here are the wires with a 4-pin connector attached to them (grounds and positives are shared).
Oh great the order is really screw'd
Here is the servo tray without the modifications.
This is how I attached the wooden supports inside the pod, magnets. And thin CA.
Making of the 4-pin connector and gluing of the aileron servos. I decided to tape them over and glue them with hot glue to the wing.
I decided to make pushrods like this all around so I can replace them easily and change the holes on servos and horns if necessary. Thin shrinktubing, thin CA and voila. Easy no-flex, no-slop pushrods. I used 0,8mm wire since the holes were that size, thus no slop at all.
More on the finished pushrods. I use the same technique for the rudder and elevator pushrods too.
Its pretty much done now!
The airframe came out at 280 gram, but it was tailheavy (no surprise there) so 20 grams of noseweight was required. With that it balances perfectly at 80mm for LE, which is factory default.
How all that is really left is get all the electronics tied down inside with the noseweight, don't want them to rattle around. Then program the radio, trims and such. Then it's maiden time and we'll see what after that! Maybe I will put that carbon cloth to the boom, I haven't decided yet. I'm not planning on tossing it hard on the maiden so I'm not afraid Ill break it without it just yet.
Shees I'm tired. More tomorrow! (Thumbs up for a good weather).
PS. Ill try to get in on video.
