In one of the reponses above it was said twice now that my motor should be approximately a 550 and good advice about the 4 cell was given. However, I still have a question becuase it was said that there are many ways to accomplish this. I know that more power is better than not enough but what are the limits. When I went through the motocalc it gave me a lot of examples of motors in the 600-800 size. I understand I need more battery and it also said I should use a 4 cell 3200. With all this said I am leaning towards more power becuase in the advice section it talked about grass and short strip take offs. I need to deal with short runways and none are paved. So its dirt, gravel, grass and not much room. Can I get your thoughts? The weights are not much different but am I creating a different problem by doing this. Trying to settle on Motor, ESC and battery setup so I can order from the states. Thanks guys.
I'm not sure that a 60" wingspan plane is your best choice for the area you're planning to fly it. It might be worth picking a plane better suited for smaller areas, and fly it while figuring out the needs of your larger build.
