Looking for EASY Glider/Powered Plans
BenHealey
I'm teaching a class about planes in late June, and all my students want to build a plane. I'm looking for a plan that is for a chuck glider, but can be converted to a powered plane easily. I need one that is just foam board and plywood, I don't have a massive budget. I do have access to a laser cutter, but it has a 500x300mm cutting area. I want a plan that can be made with that size laser with max 3 500x300mm boards. I can resize full-size .pdfs as needed as well.
Thanks a ton!
Thanks a ton!
This is a good one if you are okay with buying them!
AIRFORGE
Make It Fly!
Thanks a ton!
The EZ Pack Plans Index has many free EZ Pack plans you can download.
Also, there are many helpful options on the FT STEM Store that you can purchase.
